Previous in Forum: Mechanical Simulation for Universal Motor Operated at AC   Next in Forum: Furan Testing
Motor Thermal Curve
01/31/2011 3:30 AM
I have motor Heating and cooling time constant. Vendor has not provided Motor Thermal withstand curve (Hot and Cold)
Please suggest me how to draw Thermal withstand curve (Hot and Cold) based on available information of Heating and cooling time constant.
Is there any thermal model forumula or any example to do the so.
Thanks
Re: Motor Thermal Curve
01/31/2011 10:57 AM
There probably is a method to do this but you must consider the legal problem first. The motor manufacturer has probably provided two temperature windows for this motor. One temperature range for the powered operations and one for the unpowered storage. If you exceed these temperatures you do so at your own risk!
Likely many components outside the approved temperature regions have very non-linear characteristics. Where and how they go non-linear is anybody's guess.
Have you not learned from the Challenger disaster?
Good Answers: 804
01/31/2011 11:39 AM
What size motor are you referring to? Smaller motors tend to follow industry standards and the damage curve is supposed to be under the i2t curves you would find in a standard over load relay. If you are referring to a large and / or custom built motor, then all bets are off.
Good Answers: 170
02/01/2011 8:34 AM
Why do you need to draw the thermal curve? Hot & Cold Time Constants are enough information with respect to motor protection.
electricalexpert65 (1); JRaef (1); redfred (1)
