The dynamic braking resistor dissipates regenerative power during braking the motor by braking chopper. Single conductor cables are used for VFD to Braking Resistor. It is DC circuit. The braking chopper triggers on and off repeatedly due to actual operation. The DC cable installation is not limited to any special requirement in bunching cables or laying cables. However, someone says that IEC 60092-352 should be applied because braking chopper is on/off, on/off,....
IEC 60092-352 is applicable to single conductor cables installation for 3 phase AC circuit. is it right if this cables are applied to IEC60092-352 like AC circuit ? I am against that because repeated on/off does not drop below zero.
Help me
