I have been tasked to calculate the distribution system losses for our site, the site supply voltage is 22kV, 3P, 50Hz, AC. The metering is installed on supply side`s secondary.
I have been able to calculate the transformer losses from manufacturer`s test certificates and also know that the other losses can be calculated using P = I^2 R equation but bit confused as the system involves the 22kV suitable overhead lines and underground cables and 22kV ring mains.
Can anyone pls. advise in regards to the calculating the other losses, or refer me to the good references (book/internet links/etc)
