Previous in Forum: To be corrected the industrial coating system   Next in Forum: Changing User ID
How to Paste in a Post?
02/01/2011 11:25 AM
I can't get an answer from CR4, so does anyone know how to paste in a post?
Pathfinder Tags: paste
Good Answers: 59
Re: How to paste in a post?
02/01/2011 11:39 AM
Which browser are you using? What operating system? What are you trying to paste? If it's text and Windows you can type CTRL+V and paste. (Or right click your mouse and hit paste.)
If you're trying to paste an image or other file you'll need to follow the instructions for adding an image - keep in mind that the toolbar doesn't display in most browsers other than Internet Explorer or Firefox.
02/01/2011 11:45 AM
Firefox and W7. It's just text; I copy it and do a right-click in the post, but there is no option to paste. I'll try the Cntl+V.
Good Answers: 59
02/01/2011 11:52 AM
You can also try clicking the 'Bypass "Custom" Menu...' button (which should show up in your right-click menu for CR4); this should give you the normal right-click menu functionality.
CTRL+V should work no matter what and is a good shortcut for pasting. CTRL+C is the shortcut for copy.
02/01/2011 12:34 PM
That does bring up a new menu, but most of the choices are grayed out.
02/01/2011 12:41 PM
You need to have something copied onto your clipboard. Then when you call up the menu the applicable choice will be available.
02/01/2011 11:51 AM
Wow, Cntl+V works! Thanks so much. My right-click menu just has undo, redo, bypass custom menu and close as choices.
Register to Reply 6 comments
Doorman (1); SavvyExacta (2); SSCpal (3)
