Previous in Forum: Water Evaporation   Next in Forum: Gate Valve Material
Newton's Law of Cooling
02/01/2011 11:45 PM
salam to dears;
i have problem in solving question plz help me;question is "at 1 pm, a thermometer reading 70 F is taken outside where the air temperature is -10F (ten below zero). at 1:02 p.m., the reading is 26F. At 1:05 p., the thermometer is taken back indoors , where the air is at 70 F. What is the temperature reading at 1:09 pm?" the expected answer is 56F.
Regards
wajeeha kiran
Good Answers: 119
Re: newton's law of cooling
02/02/2011 6:16 AM
The problem involves a differential equation with an exponential solution.
http://en.wikipedia.org/wiki/Time_constant#Thermal_time_constant
With this information you can verify the correct answer.
Re: Newton's Law of Cooling
02/03/2011 6:15 PM
Sweetheart
Newtons law of Cooling is also known as the Seventhlaw of thermodynamics.
Answer is:If the thermometer was made in China and the sun is out, The reading wil be -11F (eleven below zero) if the day has more than twelve(12) hours of sunlight. The hoped for response is 3.141592653 Kelvin....if it is Tuesday.
Hope that you are enjoying your first pair of shoes.
Wahdeed
Register to Reply 2 comments
