Previous in Forum: Exhaust Hood Spray In Steam Turbine   Next in Forum: Thickness Calculation for Piping as Per ASME.B.31.1
Condensor Flash Tank
02/07/2011 4:23 AM
hello sir, There is two type of flash tank or surge pipe ie. Hp & Lp in condensor where drains of extraction, casing, ejector are drined. Whats purpose of that flash tank in condensors, what will be happen when is not present or whats effect when drains are drained in condensor with out flash tank?
Good Answers: 181
Re: Condensor flash tank
02/07/2011 5:19 AM
Again Google, it's there!
Good Answers: 12
Re: Condensor Flash Tank
02/07/2011 10:36 AM
High pressure flash tanks are designed for flashing of high pressure with high temperature condensate and divides it into
1 - lower pressure steam which can be used again with low pressure equipments like steam humidifiers, cooking kettles or low pressure heating supply mains.
2 - Low temperature condensate which driven to steam condensate tank
Low pressure flash tanks used to reduce and cool to low-pressure steam before
re-introducing it to the boiler, condensate receiver, or discharge directly into sewer.
1 - you will lost some amount of energy which recovered by flash tank.
2 - condensate flashing will occurred in cool condensate pipes and and forming a steam pockets. As steam pockets looses its latent heat, It will Vanish. The walls of water comes back together and creating water hammering in condensate pipes.
don't tell me who are you , what do you know is enough.
02/13/2011 6:28 AM
thank you sir
02/14/2011 6:51 AM
To avoid the hammering inside the steam/drip/drains lines. that is one of the main resons.
Register to Reply 4 comments
Anonymous Poster (1); khairy Aish (1); shshkntvrm (1); TonyS (1)
