Previous in Forum: New 12 Volt Amp = Buzz in AM Sound System   Next in Forum: Wattmetric earthfault
Over Current On 33 KV OverHead Line.
02/09/2011 3:37 AM
Hi All,
After an Over Current fault on a 33KV OverHead line the following two things were noted:
1. Two Wolf conductors twisted around each other,bear in mind that this is one and the same phase we have only doubled the conductors.
2. There was evidence of a Jumper melting and consequently snapping off on the same phase but at an isolation point.
Now the question is did the jumper snap off as a result of the two conductors from the same phase twisting around each other or did the conductors twist around each other as a result of the jumper snapping off?
Re: Over Current On 33 KV OverHead Line.
02/09/2011 3:52 AM
Checke the following first:-
1. Are you sure it was due to over current?
2. The electrical connection and phisical configuration of doubling wolf in same phase.
BNDas
