Previous in Forum: Calculation of Bus Bar Cross Section and Fault Level   Next in Forum: Three Phase to Single Phase
Power System Protection
02/13/2011 3:49 PM
I urgently need the definitions for the following terms in Power System Protection which are Pick up errors and Extremely inverse characteristic.
Pat77
Re: Power System Protection
02/13/2011 4:28 PM
Gee, these seem to me to be pretty self explanatory. Unless you are having trouble understanding what a pickup means in a control system. A pickup is not in this case a way for an engineer to have a good time. A pickup is a sensor, a transducer. It converts some physical property into an electrical signal that other parts of the system can use. A microphone is a pickup device. No pickup device works flawlessly. The difference between the pickup signal produced and the actual signal it should have produced is the error.
Good Answers: 181
02/13/2011 4:31 PM
You have advantage of the Internet and yet you still want somebody else to do the donkeywork.
02/14/2011 5:34 AM
pick up error is the tolerance error % allowed for pick up voltage of a coil in relays, contactors etc.. Extremely inverse characteristic is one the curve which is used for inverse definite minimum time overcurrent & earth fault protection.
You don't understand anything until you learn it more than one way.
Register to Reply 3 comments
redfred (1); TonyS (1); vijaymail_electrical (1)
