Previous in Forum: Turn Table with Pneumatic Vibration   Next in Forum: Sizing of Industrial Furnace
Effect of Hot Rolling Parameters on Yield Strength & R Bar?
02/14/2011 1:09 AM
What is the effect of hot rolling coiling temperature and finishing temperature on yield strength and R bar value of low carbon cold rolled closed annealed steel?
I hear that there is major role of above parameters on drawability of steel.
Please share your knowledge.
Re: Effect of Hot rolling parameters on Yield strength & R bar
02/14/2011 8:53 AM
We have been able to up the yeild/tensile a bit by slow cooling. Helps refine the grain structure.
Ron
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
02/15/2011 12:10 AM
Mr.Ron,
Thanks for your response.
In some literatures stated that higher finishing tempearture with lower colling temperature gives higher R bar value.
As per my practical knowledge Hgher coling temperature gives lower yield strength. After cold rolling, annealing and skinpassing in 0.050% carbon with Manganese 0.18% steel coiling at 620 deg gives lower yield strength compare to coiling at 580 deg.
regards
K.K.Rao
You might be interested in: Bar Code Software, Bar Code Cards, Bar Code Scanners
