Previous in Forum: The Next Generation of Wiki Leaks   Next in Forum: Unidentified Noise from an Aircraft at the Gate
13 comments
India - Member - New Member
Mobile Chargers
02/17/2011 2:50 AM
Hai,
Everybody knows each and every mobile phones having different types of chargers and outpu the terminal pins.One cannot use another mobiles charger.
What is the need of it? If everything becomes same it will be more benificial to all of us or wrong?We will also reduce the E-waste.
sreedhar.r
Re: Mobile chargers
02/17/2011 4:09 AM
Thank you for your guidance
sreedhar.r
Re: Mobile chargers
02/17/2011 5:59 AM
Re: Mobile chargers
02/17/2011 6:58 AM
That's a good start. There are thousands of things that I wish they would standardize. Sure would make life easier.
Good Answers: 164
Re: Mobile chargers
02/17/2011 7:44 AM
Even better would be this :
witricity
Re: Mobile chargers
02/18/2011 12:08 PM
Since the best of these things are very inefficient, why are they even allowed if energy conservation is at all important? -- JHF
Re: Mobile Chargers
02/17/2011 11:01 PM
I agree with all of you guy. Yes as somebody said there are alot of things which should be standardized.
I ask the same question about Car parts. If you talk about exterior things like head lights body parts back lights etc so there is a reason which is "look" but I say we can still standardize few models from all manufacturers with different brand names eg starting from suzuki to mercedes and BMW all should have same dimesions and design for these models so that we can interchange parts and can get varity of qualities for the same part also it will bring the price lower to a great extent.
rizwan
Re: Mobile Chargers
02/17/2011 11:48 PM
Give up on auto standardization. We used to have the same headlight bulbs, but even in Model T days, auto companies wanted to seem special and headlights were often the easiest and most obvious symbol.
Re: Mobile Chargers
02/18/2011 3:42 AM
Commercialization limits standardization
APIX Pilot Plant Design Project - Member - New Member Engineering Fields - Chemical Engineering - Member Engineering Fields - Environmental Engineering - New Member
Re: Mobile Chargers
02/18/2011 12:04 AM
The need of this was to ensure income for mobile phone manufacturers, for ensuring that a customer keeps coming back to the outlet to buy a charger and is again tempted into the same brand again.
Also following standardization of chargers (like a generic pharma market) a lot of players will jump into the market with "cheapest" being their target, this will kill the phone manufacturers exclusivity!
Another example is the standardization of headphones in mobile phones (also a very recent concept)
Oh, the woes of industrialization :)
Shalom
Re: Mobile Chargers
02/18/2011 7:48 AM
your suggestion is good.In practical it is difficault.If similler type of any things require standard approved by common technical board of Indianominated by specialist approved by govrment or TRUST is require.
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: Mobile Chargers
02/18/2011 11:04 AM
It'll never happen. Manufacturers will lose money. Nuff said.
Re: Mobile chargers
02/18/2011 12:03 PM
Not that I don't trust big business or big government, but in my mind the real reason for standardizing is to not send a charger with a new phone, but not reduce the price. This will also generate sales of new chargers whereas they are give aways now. -- JHF
Re: Mobile Chargers
02/18/2011 11:57 PM
Please check
http://cr4.globalspec.com/thread/57468/US-Trimmer-Adaptor-in-India
1. All the personal battery operated trimmers' & Mobile-Phone chargers are same in internal design [Voltage & current rating] and only differ in the out-put plug. May be used by changing of out-put plug without any reservation.
2. All Laptops [most names] have the 19~20VDC output [in current ratings differ] have different out-put connector.
Some manufactures have a 3rd pin to sense and control charging but other ratings are compaible.
You will be astonished to note that Laptops using so called 6 cell batteries [~ 10V] are using the same 19/ 20 V chargers.
So any properly rated voltage and current rated can be modified to use at much lower cost.
See the different connectors in the output
Register to Reply 13 comments
Anonymous Poster (2); Circuit Breaker (2); Haajee (1); JohnDG (1); kramarat (1); kvsridhar (1); mrswamy (1); Out of Box Experience (1); rizsaeed (1); rsreedhar1987 (1); zasmine (1)
