Previous in Forum: Air Heater Leakage Test   Next in Forum: Engineer
Overhead Crane Wheel E N 8
02/17/2011 9:29 AM
Hello Every1
Please let me know Crane wheel used on track can be manufactured in S.G.Iron. Grade 800/2 ?
there is any problem like rust if the S. G. iron wheel is in Rain water?
Or E N 8 Casting is prefered. is it possible to machine the casting or forged wheel after heat treatment?
S G Iron 800/2 machanical prop.:- U T is 800 / Y S is 471(Mpa)/ Elongation 2%/ Hardness 245-335.
Thanks for your valued time.
Best Regard's
Re: Overhead Crane Wheel E N 8
02/18/2011 3:39 AM
hi
this might be useful to you
AISI C1045
Description C1045 is a medium range carbon steel. This is a common precision shafting grade and is ground and polished to closer tolerances and a better surface finish than cold drawn bars. The increased carbon content means improved mechanical properties and higher strength than C1018. Slightly different welding procedures are required.
Chemistry C Mn P max. S max.
.43/.50 .60/.90 .040 .050
Minimum Mechanical Properties Inches Tensile Strength
ksi
Yield Strength
ksi
Elongation
Reduction of Area
Hardness
BHN
5/8 - 7/8 Incl.95851235187
Over 7/8 - 1-1/4 Incl.90801130179
Over 1-1/4 - 2 Incl.85751030170
Over 2 - 3 Incl.80701030163
bye
