Previous in Forum: Smoke Detectors Radius Coverage and Clearance   Next in Forum: Adhesive Cable Supports
Transistors
02/21/2011 10:04 AM
Like all berylium compounds, BeO is carcinogenic and may cause chronic beryllium disease. Once fired into solid form, it is safe to handle as long as it is not subjected to any machining that generates dust.[7] Beryllium oxide ceramic is not a hazardous waste under Federal law in the USA.
NEVER cut open a transistor (usually RF products) which may contain this. It's worse than asbestos. It causes mesothelioma if inhaled, even in small quantities. Actor Steve McQueen died from this disease.
Re: Transistors
02/21/2011 10:28 AM
Sorry about the second "q". it was meant to be "a".
Message remains. Don't cut open transistors if you don't know what they contain!! ! !
Re: Transistors
02/21/2011 10:47 AM
OK, I won't.
Re: Transistors
02/21/2011 11:37 AM
Yes, beryllium has been identified as a probable carcinogen. However this does not mean every tiny exposure "causes mesothelioma" as a certainty, which seemed to be implied.
http://www.hanford.gov/page.cfm/BerylliumFAQs
True, it's certainly not something you'd want to sprinkle on your breakfast cereal. Care should be taken to minimize exposure - particuarly to airborne particles.
But come to think of it, who cuts open transistors on a regular basis? I suppose the occasional curious student might do it once or twice though, so the warning is appreciated.
Re: Transistors
02/21/2011 12:50 PM
The problem is, not BeO in solid form, but ground or cut. If the dust is inhaled, it stays. If you smoke too, what flowers do you want?
Also if the dust gets into a cut or scratch, it causes a permanent white scar like a tattoo.. I've got one. Took ages to heal.
Register to Reply 4 comments
