Previous in Forum: UL Listing Number   Next in Forum: How Do I Mantain Even Deposition During Electroless Nickel Plating
Hot Stamp Process
02/21/2011 7:51 PM
Is the policarbonato compatible with the Heat transfer or Hot stamp?
Re: Hot Stamp Process
02/21/2011 8:09 PM
Yes, it is. Polycarbonate is easy to stamp. It may take some added heat.
02/22/2011 11:05 AM
I have a problem for stamp in the Polycarbote, the label doesn't adhere to completely to the plastic.
02/22/2011 7:55 PM
Semantics again. Hot stamp implies an ink transfer process using a heated stamp pad. Labeling is a room temperature process with all the lettering on a "sticker".
Which are you doing? Stamping, or labeling?
02/22/2011 7:59 PM
Hot stamp process..
02/22/2011 11:29 PM
Arley_za,
may be lynlynch was asking is the hot stamping process portion of the label (example some artwork or some alphabet only)
is your situation is when you use hot stamping foil on your PC (polycarbonate) the foil can't adhere?
If this is the situation check:
1.is the PC film suitable for hot stamping?
2. is the hot stamping foil suitable for PC?
3. is hot stamping temperature suitable?
Regards
Anonymous Poster (1); arley_za (2); lyn (2)
