Previous in Forum: Multi Axis Controllers   Next in Forum: Cable Core Choosing
21 comments
Circuit Breaker
02/22/2011 5:44 AM
What is the meaning of "Icu,Icw,Ics,Isc" and What are the differences between them
Best regards
Re: Circuit Breaker
02/22/2011 5:50 AM
Using the same skills that brought you here, search for these terms on the internet.
Once you learn to search for yourself, you will no longer have to ask other people to do your work, and your thinking, for you.
Best regards.
Re: Circuit Breaker
02/22/2011 6:51 AM
Hey now...be careful throwing crazy advice like that out there. You're about to upset a bunch of political parties with such notions!
Re: Circuit Breaker
02/22/2011 10:35 AM
CR4 ADMIN: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
Re: Circuit Breaker
02/22/2011 11:43 AM
Guest,
I understand your irritation and I have also scolded responses which consisted of "look it up". And perhaps Lynlynch's response was a little lacking in tact. But your own response was utterly devoid of it.
It seems to me that lately there's been an increase in questions which are phrased in such a way they can be read that the OP hasn't bothered to do their own research. Maybe this is a misperception on my part, maybe it's due to language barriers, maybe it's correct. I can see Lynlynch's thought process when he read the OP's question. Had it been worded differently then his answer would have probably been quite a bit better.
Of course that's no excuse for poor CR4 ettiquite on his part - or yours. Or mine, for that matter. So let's all take a moment to think about civility and make CR4 a better place, shall we?
Re: Circuit Breaker
02/22/2011 11:50 AM
Until you register and distinguish yourself from the insulting guests who hide behind the cloak of anonymity, your opinions are as meaningless as the rest of the drivel spouted by most "Guests".
It just sounds like you're talking to yourself.
Re: Circuit Breaker
02/22/2011 12:27 PM
Yes well, until I see anyone else here with my exceedingly high intellect I guess talking with myself will just have to do.
Re: Circuit Breaker
02/22/2011 12:34 PM
Try to do it quietly then, so as not to disturb us feeble minded members.
Re: Circuit Breaker
02/22/2011 1:52 PM
Since you responded in a somewhat intelligent manner, I would call this a true conversation.
Re: Circuit Breaker
02/22/2011 2:09 PM
Re: Circuit Breaker
02/22/2011 2:33 PM
Irrelevant This post was deleted because it is related to a deleted post and would otherwise be taken out of context.
Re: Circuit Breaker
02/22/2011 1:51 PM
This is the place to do research. This is an open forum, where they get together, crack a few beers, and talk out their technical to-do list. When someone walks up to the group with a beer and asks a simple question and is told to pack sand, that's just plain rude. And very dick-like.
Normally this would not be practiced in human form, but some douches on the board like to throw their imaginary weight around and just tell people to shove off.
Good Answers: 116
Re: Circuit Breaker
02/22/2011 7:14 AM
These apply to the parameters of circuit breakers and contactors.
Schnieder Electric are one of the biggest makers of this kind of device for distribution boards, motor starters - with brand names like Telemecanique.
http://www.schneider-electric.com/sites/corporate/en/home.page
If you delve into their website for contactors, like I did, you should find that they have technical information and memoranda which explain these terms (and much more). For example "Cahier Technique No. 150 - Development of Circuit Breakers to IEC 947-2".
One has to keep trying different menus and documents till the right area is found.....
It is like the food Supermarket - At Tesco, I learned, in time, that (there being no "tinned meat" or "canned meat sign) "tinned meat" was (with the tinned vegetables) under the sign "Canned Vegetables" - it appears "Canned" was the important word in the mind of the planner.
Re: Circuit Breaker
02/22/2011 7:46 AM
Icu = Rated Ultimate Short Circuit Breaking Capacity of a Circuit Breaker - This implies the maximum RMS value of short circuit current that the Circuit Breaker can safely break for a operating duty cycle O-CO. After clearing the rated Icu twice, the breaker becomes unusable again.
Ics = Rated Service Short Circuit Breaking Capacity of a Circuit Breaker - This implies the maximum RMS value of short circuit current that the Circuit Breaker can safely break for a operating duty cycle O-CO-CO. After clearing the rated Ics thrice, the breaker can be used as a Switch till replacement is received. But, no more short circuit clearings. Ics can be either 25% or 50% or 75% or 100% of Icu.
Icw = Rated Short Time Withstand Current - This implies the maximum RMS value of short circuit current that the breaker can safely carry for a given duration (e.g.) 50kA for 1sec. This is an important specification, because in co-ordinated networks, all the breakers may have to continue carrying the fault current till cleared by the uppermost stream breaker - in case the down stream breakers fail to clear the fault.
The above three are very important specifications for an LV Circuit Breaker.
Isc = Short Circuit Current (more system related)
Good Answers: 170
Re: Circuit Breaker
02/22/2011 7:48 AM
Forgot to login. The previous answer was given by yours obediently "ee65"
Re: Circuit Breaker
02/22/2011 10:36 AM
Thank you.
Good Answers: 116
Re: Circuit Breaker
02/22/2011 2:00 PM
  1. So what is a duty cycle O-CO? Or O-CO-CO? Does "O" mean overcurrent, off or open? Does "C" mean clear or close? Or something else?
  2. Seems like a code Icu or Ics defined using two other codes O and CO.
India - Member - New Member
Good Answers: 164
Re: Circuit Breaker
02/22/2011 9:55 PM
IEC 60947 definitions : Open - 3 minutes - Close/Open (without intentional delay between the C and O)
CB requires to clear O-CO at Icu and O-CO-CO at Ics.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Re: Circuit Breaker
02/22/2011 9:58 AM
Every one has the right to ask and answer...Go 4 Piece
One system
Re: Circuit Breaker
02/22/2011 10:37 AM
Amen, brother.
Re: Circuit Breaker
02/22/2011 2:41 PM
Lyn
Maybe Next time I am on Phoenix for the BCS game I can stop by for a free meal and a beer.
Re: Circuit Breaker
02/22/2011 2:50 PM
Come on over.
Register to Reply 21 comments
67model (2); Anonymous Poster (10); electricalexpert65 (1); kvsridhar (1); loadshare (1); lyn (5); wareagle (1)
You might be interested in: Circuit Breakers, Radio Receiver IC, Load Centers
