Previous in Forum: Depth of Excavation   Next in Forum: Beam on elastic foundation
Concrete core sample
02/22/2011 9:29 AM
I have done a 3" core sample from a concrete spun pile which design to Grade 80 concrete, but suprising the result given only showed 40N/mm2.
Why such a big different between the compressive strength of the concrete using 150x150 test cube vs a core sample? I though they should be the same regardless the size of the sample.
Pls help if anybody have the same experience.
Regard.
Re: Concrete core sample
02/22/2011 1:18 PM
Are the samples the same area exposed to compression? Compression is, after all, measured in Pounds per Square Inch (PSI) or MPa. I get about 7 in2 for the cylinder, and about 35 in2 for the cube.
That is the nice thing about standardized tests... something is varied while several things are held constant. This gives the value being investigated.
02/25/2011 10:49 PM
This differents is effect of friction on contacts of press plate and concrete. This friction give a most strength for deviatoric stresses. Effect of this friction depend on cube size (and shape of sample, and high and width of sample, etc.)
If you can delete friction, the different of compressed strength will be vanished. According to National Standart of Russia, investigations is worked with friction on the contact of steel press plate and dry concrete for cube with 150mm edge. Theare is cofficents for convert "150mm" cube strength to "200mm" and "100mm" cube strength.
Please, sorry for my English...
Russian civil engineer
03/06/2011 9:34 PM
As per IS standards the cube to cylinderical convertion ratio is 80% . For M80 you should get 64 N/mm2 minimum. At the same time the Dia to Depth ratio of cylinderical sample not more than 2.
The result also depends upon the compaction of pile and voids present in the sample.
I have done the same test several time. But it will not give a require strength.
N.Vigneshkumar
Register to Reply 3 comments
Doorman (1); Evgeny (1); jai.vignesh (1)
