I have just started with a new company as the reliability engineer and have been asked to look at the problem that has been around forever, 20 years, with a fresh set of eyes.
Has anyone had any experience with this model of fan? The problem seems to have originated around fatigue cracking of the impellers, which was responded to by "beefing up" the impellers. The current impellers are 15% heavier than the original design and left no room for the anti-thrust vanes that were part of the original design. The root cause of this cracking was never determined and while the applied solution seems to have slowed the growth rate of the cracks so as to fit in with a major shut interval it also seems to have increased the axial load on the DE bearing by an order of magnitude.
The problem is perceived as a DE bearing issue as this is the bit that breaks, is replaced and shows up in the maintenance costs and a lot of effort over the last 15 years has been directed at the bearings. The bearings are still failing due to axial overload and a bearing solution is still perceived as the most cost effective.
I would like to address the root cause of this problem so that the impellers don't crack, the bearings are not overloaded, maybe change a few perceptions here and the next new reliability engineer can have a new problem to 'get to know ' the plant. I am open to suggestions.
Regards
Henry
