Previous in Forum: Smart materials   Next in Forum: The Difference Between Ia And Pa
Material Composition of 9Cr2Mo
02/26/2011 2:12 AM
Can anybody please give me the chemical composition of this material or an equivalent Indian grade material to chose in the option of this material.
Thank you for your answers.
CNC Solution Provider
Good Answers: 11
Re: Material composition of 9Cr2Mo
02/26/2011 3:30 AM
The chemical composition is on its name, Cr-Chromium , Mo -Molybdenum
Like what is your main concern? Strength or Corrosion Resistance or electric properties, Temperature service, we don't know. So we don't know what's the equivalent
Provide more details & application.
02/26/2011 3:47 AM
Yes I know that the composition is in its name but I want the detailed chemical composition of this material as if I have the details of the composition then I can look in to my data which I have with me of other local metals and find an equivalent material.
The application is to make a specific Ring of Dia 600 mm having 90mm thickness which is to be hardened up to 48-52 HRC and will be used as a Fin in the Roll used for the Pipe manufacturing line.
Thanks for your answer though.
Good Answers: 11
02/26/2011 4:34 AM
My hands are up, with the materials engineer. I'm not so much into material science, but as far as I know, CrMo, from the name alone suggest an alloy of steel in used in heat service - actually this is typical a stainless steel additive that sometimes it goes along with Nickel & Ti
see
http://en.wikipedia.org/wiki/Stainless_steel
Material Engineers, go ahead.
02/26/2011 5:47 AM
Thank you for the answers. But I would like to tell you that this is not a stainless steel family metal it is an Alloy Steel Grade.
Re: Material Composition of 9Cr2Mo
03/02/2011 7:36 AM
9% Chromium, 2% Molybdenum?
03/03/2011 2:37 AM
Thank you for your answer but that was not the total composition it was only derived from the name itself which I also knew. But finally I found it some where else if any one wants then it is as below.
Carbon(C) - 0.08/0.12
Silicon(Si) - 0.3/0.5
Manganese(Mn) - 0.9/1.2
Chromium(Cr) - 9/10
Molybdenum(Mo) - 1.9/2.1
Vanadium(V) - 0.25/0.35
Niobium(Nb) - 0.35/0.45
Now this is called the detailed composition of any kind of metal.
Thank you once again.
Good Answers: 11
03/03/2011 2:51 AM
I guess you answered your own question. Now that's a good start. I'm happy for you.
Register to Reply 7 comments
Anonymous Poster (1); Noudge79 (3); uniq_engineers (3)
