Previous in Forum: Tripping of Generator in High Voltage Protection   Next in Forum: Voltage Source Inverter
Power Factor Improvement For D.g Set
02/26/2011 6:38 AM
can we connect capacitor bank after d.g set?
Re: power factor improvement for d.g set
02/26/2011 7:00 AM
No please dont do it
Reply Score 1 for Off Topic
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Re: Power Factor Improvement For D.g Set
02/26/2011 8:54 AM
If you ask something, please decribe it completely !
One system
02/26/2011 9:22 AM
Yes. For what purpose? Presumably for power factor control? (Ahh, yes--I should have read the title of the thread.) It would be the same as power factor control capacitors used anywhere else.
I would question whether you really needed them--I wouldn't expect your "transmission lines" to be that long that you'd save significant money by switching to smaller cables.
Hmm, on the other hand (I'm not a generator expert), maybe you'd get more power out of the generator (kilowatts) if the generator isn't also generating kvars--I'm assuming the kvars would add heat to the windings...
03/01/2011 8:23 AM
After more thought, I'm certain that the kvars (or the current flow due to the kvars) will add to the heat rise in the generator windings. If you could get rid of the kvars in the generator (i.e., supply the kvars from power factor correction capacitors external to the generator (where else would they be ;-)), you will be able to get more kilowatts out of the generator.
So, it my indeed make sense to add p.f. capacitors.
Good Answers: 170
03/01/2011 3:46 AM
Please refer to an earlier thread on the subject I had published a detailed paper on the subject in that thread.
Anonymous Poster (1); electricalexpert65 (1); loadshare (1); rhkramer (2)
