Previous in Forum: Carven Motor Really Works?   Next in Forum: Buoyancy Calculation
Class 2 Power Supply
02/26/2011 9:38 AM
I have a speaker system that needs ; INPUT 120VAC 60Hz 32W OUTPUT;12VAC 1800mA
Re: class 2 power supply
02/26/2011 9:53 AM
Are you sure about the AC output? If so, all you need is a transformer. If you mean 12VDC, you'll find thousands of them with Google.
Terms and conditions apply. Other search engines are available.
02/26/2011 2:43 PM
I took infoe from the old power supply so the infoe is right. I've been to raideoshack. They say they cant get 1800mA. there telling me that they only go as high as 1500mA witch will damage my speekers
02/26/2011 3:31 PM
Who told you it would damage your speakers? That is very unlikely. Even less likely than that. I can't imagine how that would happen. You might get distortion, but, at low volumes, you probably won't even get distortion.
Still, if you're going to buy something, get the right thing--see the DigiKey link that somebody else posted.
02/26/2011 10:04 AM
I assume (I know) that the ratings you've specified come from the existing power supply which is presumably (ditto) no longer working. And, you presumably, are asking what you can use in its place?
What you need is almost any power supply rated to deliver 12 VAC at 1800 mA. You might use any power supply that can deliver 12 VAC and at least 1800 mA. if it is a well regulated power supply. Some of those little "power bricks" have no regulation--the only "regulation" supplied by the load--thus a higher rated one might deliver a much higher voltage at no load (or below rated load) that could damage your speaker system.
You might also get away with one that delivers 12 VAC at less than 1800 ma. if you don't use it at high volume levels. (You might also get distortion in that case.)
Re: Class 2 Power Supply
02/26/2011 3:08 PM
this place has many to choose from. http://www.digikey.com/
02/26/2011 3:53 PM
I may be dumb, but I had a heck of a time trying to find a 12 VAC transformer there (with their paper catalog, no problem).
So, I googled on ["power supply" "12 vac" 1800ma]
Here's one that will do the job from http://www.fitnessrepairparts.com/part_search/CatalogSearch/ac%20adaptor/25/0/225
AC - AC Adaptor, 12 VAC, 2500 MA
Wall mounted AC adaptor, Input = 120 VAC, Output = 12 VAC @ 2500 MA - Unregulated
Ignore what I said earlier about regulation--I was thinking more of a DC supply than an AC supply, you won't have a problem with this.
Register to Reply 6 comments
JohnDG (1); loneeagle (1); rhkramer (3); tcmtech (1)
