Previous in Forum: Remote Guided Camera on Wheels to Explore Rabbit Burrows   Next in Forum: Sun Position Sensor
Radiomarelli TV Set
02/26/2011 9:51 AM
I have a Radiomarelli TV set which has this fault!
When I give mains power to the set, it tries to switch on standby but immediately refrains from this.
The Standby LED only blinks briefly.
At first I thought its the switch contacts but I verified by testing the switch using DMM.
Anyone has an idea on what part or component could be faulty?
Thanks Guys
Good Answers: 120
Re: Radiomarelli TV Set
02/27/2011 6:48 AM
It may be a shorted capacitor in the medium voltage power supply, when the set powers up the short is detected and the set shuts down as a protective measure. Other shorts, like pinched wires, blown transistors,etc can do the same.
Per Ardua Ad Astra
02/27/2011 11:36 AM
By the time I read your reply I have already found a tantalum cap of value (1n J 1600) which physically looks burnt out. Infect one leg dropped out while de-soldering it. I will have to wait until after the weekend to buy one & replace it. Hope there aren't more faults but this makes sense as the capacitor is connected to a large transistor in the power supply section. I assume it was turning off the transistor. We'll see when I replace it.
Anyway thanks for your reply!!
Register to Reply 2 comments
