Previous in Forum: Bus Pt And Line Pt   Next in Forum: Electrical Protection
Power Protection System
02/27/2011 10:11 AM
I couldnt understand the difference between Numerical Relay & Digital Relay???
Because both of these realys are programed in accordance with microprocesser.
Can anybody please tell me the diffrence between them???
“Build a man a fire and he will be warm for one night. Set a man on fire, and he will be warm for the rest of his life.” - Sun Tzu
Re: Power Protection System
02/27/2011 10:17 AM
Numerical relay is DSP based. Digital is microprocessor controlled.
02/27/2011 10:27 AM
Thanks
02/27/2011 11:49 AM
So in essence the numerical relay doesn't need any A/D conversion?
02/28/2011 1:51 AM
refer
http://www.globalspec.com/reference/14859/121073/chapter-9-protective-relays-section-3-numerical-relays
There is nothing either good or bad, only thinking make it so -
02/28/2011 12:08 AM
The digital protective relay, or numeric relay , is a protective relay that uses a microprocessor to analyze power system voltages and currents for the purpose of detection of faults in an electric power system. General characteristics of a digital protective relay include:
  • The relay applies A/D (analog-to-digital) conversion processes to the incoming voltages and currents.
  • The relay analyzes the A/D converter output to extract, as a minimum, magnitude of the incoming quantity, commonly using Fourier transform concepts (RMS and some form of averaging are used in basic products). Further, the Fourier transform is commonly used to extract the signal's phase angle relative to some reference, except in the most basic applications.
  • The relay is capable of applying advanced logic. It is capable of analyzing whether the relay should trip or restrain from tripping based on current and/or voltage magnitude (and angle in some applications), parameters set by the user, relay contact inputs, and in some applications, the timing and order of event sequences.
  • The logic is user-configurable at a level well beyond simply changing front panel switches or moving of jumpers on a circuit board.
  • The relay has some form of event recording. The event recording would include some means for the user to see the timing of key logic decisions, relay I/O (input/output) changes, and see in an oscillographic fashion at least the fundamental frequency component of the incoming AC waveform.
  • The relay has an extensive collection of settings, beyond what can be entered via front panel knobs and dials, and these settings are transferred to the relay via an interface with a PC (personal computer), and this same PC interface is used to collect event reports from the relay.
  • More complex digital relays will have metering and communication protocol ports, allowing the relay to become an element in a SCADA system.
Good Answers: 170
03/01/2011 3:33 AM
Yes! In principle both are the same. It is only that ABB coined the word "Numerical Relays" - when they brought in their Digital Relays into the market.
Register to Reply 6 comments
amarnath.sn (1); Anonymous Poster (1); electricalexpert65 (1); guru_88 (1); lyn (1); Panneer Selvam (1)
