Previous in Forum: SPI   Next in Forum: Control Valves
8 comments
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Convert Time into Parameters
02/28/2011 9:47 AM
Dear all,
Problem with the conversation math is as follows.
kt: 0.05 ~ 1
time: 0.05 ~99 (second)
It means kt =0.05, the delay time would be 0.05sec.
How to set the kt when I want the delay time is at 10 sec?
Please enlighten me in this.
Regards,
Anything that can go wrong, will go wrong
Re: Convert Time into Parameters
02/28/2011 10:32 AM
I hope this isn't homework!
kt ≈ (9.6 x 10-3 x time) + 0.05
From this:
time = 0.05 => kt = 0.05048,
time = 99 => kt = 1.0004,
time = 10 => kt = 0.146
Not exact, but quite close.
The reverse operation (for checking the results) is:
time ≈ (104.16 x kt) - 5.16
(I'm not going to explain how I did it, because if it is homework, you should work it out yourself ).
03/05/2011 11:41 PM
JohnDG:
This is not a homework and I am wondering where you take 9.6.
If the current: 120% to 200%
The real current in the system: 570 amps
Scale kt: 0.1 ~ 1
What if I want to set the kt is at 130% of the real curent?
03/06/2011 5:19 AM
Sorry, but you have lost me. You were asking about time in your first question - now it's changed to current. What is this about? Please explain.
03/06/2011 6:22 AM
JohnDG:
There are two cases. I am sorry not being clear at first. I am setting for the protection relay and I need to confirm.
03/06/2011 7:07 AM
Ok, for the current case:
What is the current corresponding to a trip value of 100%?
03/06/2011 11:21 AM
It is the real current of 570A.
03/06/2011 6:44 PM
I could give you the sums to find the answer mathematically, but it may be more practical for you to use the graphical method.
Take a sheet of graph paper (paper ruled with vertical and horizontal lines) and draw a graph like this:
The bottom left point is (kt=0.1,I%=120) and the top right point is (kt=1, I%=200).
If you look up the vertical axis to find 130%, you can read down to find the corresponding value for kt (0.21).
I'll show you the mathematical method if you want, but I think you'd be better using the graphical method - just get hold of some graph paper and plot it out.
Here's a close-up view of the region of interest:
03/06/2011 10:44 PM
Thank you for your time working out these graphs, it would be much helpful to me. If I need to explain to someone else, I will use the graphical method.
I am Ok now for the methematical method.
Register to Reply 8 comments
