Previous in Forum: sheet metal forming   Next in Forum: Looking for someone to set up lathes
Shaveability of steel rod - Steelwool manufacturing
04/04/2007 9:51 AM
I want to get in to the business of steel wool manufacturing but not quite sure of the parameters to check. I would like to start with a trial and see how it goes. I am using low carbon steel rod in as rolled condition. Will this have an effect on the shaveability of the steel? Regards
Re: Shaveability of steel rod - Steelwool manufacturing
04/04/2007 3:17 PM
Steel wool is made of very fine steel wire cold drawn and with a high carbon content. It is not made by shaving steel rods.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Good Answers: 120
04/04/2007 11:16 PM
steel shavings will also be very brittle = break, which you do not want in finished products. Steel wool is also a mature technology and you can buy it very cheaply and it is also capital intensive to set up = barrier to your entry
Per Ardua Ad Astra
Good Answers: 243
04/05/2007 11:24 AM
Contrary to other posts, the process involves both shaving and Low carbon steel.
Cold drawing sizes the rod ahead of the machine so that the cutters can get a consistent depth of cut, but drawing by itself was NOT the way that the indivdual filaments were prepared. Also drawing was not in my experince a separate process.
I was lab supervisor at a mill that produces thousands of tons of rods for this product. The steel was Low carbon, and we held certain nonmetallic constituents (silicon, phosphorus, and sulfur are nonmetallic) to very low levels as they could create a nucleation site for the shaving to break. (if they had tried High carbon or medium carbon, the filaments would be tougher, springier,m and tended to break. Steel wool requires soft, ductile, bendable fibers in order to clean and not scratch).
There is an excellent site describing the process here:
http://www.answers.com/topic/steel-wool
This sites answer corresponds with my experience. Be careful about rod defects, as they will bcause the filaments to break, and cutting wool wire needs a controlled chip!!!
milo
Register to Reply 3 comments
aurizon (1); BrainWave (1); Milo (1)
