Previous in Forum: Westermann Table   Next in Forum: Active Dry Mode Air Conditioning System
IN CPU
03/02/2011 5:15 AM
the tv yoke can retain its power for some interval of time ,even if the power is off, so it is possible to reuse the power in the smps
Pathfinder Tags: less
This discussion was "closed" on 03/02/2011 6:18 AM. No new comments are allowed.
Message from admins:
Duplicate thread - please discuss in the original post: http://cr4.globalspec.com/thread/66566
Re: IN CPU
03/02/2011 5:36 AM
Not effectively.
Most electronic equipment retains some charge in its capacitors, this small amount of power could perform some trivial task after switch off, but I don't see how it could be harnessed to anything useful. In general if you extract residual energy you will only have to replace it next time the device is powered up. Often there are bleed resistors to avoid high voltages lingering too long for safety reasons. Aslo highvoltage desn't equate to high power.
(BTW. I heard you the first time...)
You might be interested in: CPU Cards and Modules, CPU Chips, CPU Fans and Coolers
