Need to do repair & service work in manhole with 12.5kV cables (10 energized, 1 dead). What rules & procedures do you use for this. No splices there & all cables are triplexed shielded single conductors, over-wrapped. All exposed metal is bonded. Cables date to 1970. Will replace sump pump & its disconnect, muck out bottom of manhole, and see if transite duct to next manhole is intact for new cable installation. My thoughts: before entering pump out water (some cables immersed now), blow air in to dry, wear 40cal arc flash suit until cables covered with rubber blankets, then do other work. De-energizing all cables is a very remote possibility. Utility delivers power at 12.5kV & we then distribute 12.5kV to various buildings from central plant, with substations in each building. We would also follow standard confined-space entry procedures (USA).
