Previous in Forum: Image Recognition   Next in Forum: Spam Obfuscation
Good Answers: 97
VBS Program Question
03/08/2011 2:26 PM
I have this script that I run prior to running one program. 'VBScript Example Set WshShell = WScript.CreateObject("WScript.Shell") WshShell.SendKeys "{CAPSLOCK}" This will turn the caps lock on and the database that I built uses all caps. The program that I wrote used to turn on caps but that doesn't work in Vista for some reason. The above script is a simple work around. The problem is sometimes the caps lock is already on and then the script turns it off. I don't know how to write a script that would check first to see if caps lock is on and if it is leave it alone but if it's off then turn it on. Any help appreciated.
Pathfinder Tags: VBS
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: VBS Program Question
03/08/2011 5:06 PM
hope this helps....
My.Computer.Keyboard.CapsLock this is a boolean that returns true if the caps is on and false if it is off.
adding an if/then statement sounds like it would do the trick... something like...
if My.Computer.Keyboard.CapsLock then
else if
<Your scripting>
end if
Sometimes my thoughts are in a degree of order so high even I don't get it...
03/08/2011 6:18 PM
Sounds good to me.
Like to hear whether it works .
Register to Reply 2 comments
