Previous in Forum: Basics of FEA   Next in Forum: Compartmented Tank-Water Flow
Gear Hobbing Cutters Querry
03/09/2011 8:14 AM
How do i confirm if i can use an existing hob cutter to hobb a new gear pair..can anyone tell me what to check and if there is any formulae or programme for it. I was thinking only pr angle module and tooth depth and hob tip radius were to match now i hear you can cut gears with diffferent module cutters too. plz help me out...
sam
sam
Pathfinder Tags: gear hob
Good Answers: 181
Re: Gear Hobbing Cutters Querry
03/09/2011 10:44 PM
Only you can determine if the cutter will suit, it can only be done by comparison.
It's 30 years since I last cut a gear!
03/10/2011 11:52 AM
A Hob cutter is defined by its Module
Therefore, a hob cutter can cut gears of the same module but with different number of teeth (different dametres).
If you want to cut a gear of a different module, then you use a diiferent hob cutter with the correct module size.
A Module defines the size of the tooth and its geometry in terms of shape, tip angle (as you say) etc. You need a small course in gear design to understand all of this. You can search the web for gear cutting and design...
Register to Reply 2 comments
