Previous in Forum: Spy Phone Design   Next in Forum: about DCERPC...
Fluke Repair
03/09/2011 11:51 AM
Ok so I'm going out on a limb here but its all I have left as Fluke wont help me because they say they offer technical support on repairs...and the service centers have not been able to help me either.
I have a 718 30G out of warranty, it wouldn't hold pressure. So i sent to a service centre for them to tell me it could be the pump diaphragm but they were not sure and it would cost close to $1000 to take the chance. I said to hell with that I'll find the problem myself, so after taking the unit apart I found that it clearly was not the pump diaphragm it was a small nozzle that feed the pressure from the pump into the sensor assembly. Whats happened is the glue or adhesive used to attached said nozzle onto the sensor has dried up and the piece had fallen causing all the air to leak whenever the pump was pushed.
Bottom line I'm trying to find out if anyone knows what kind of glue/adhesive is used to attach such a piece onto the back of this sensor which is located directly on the circuit board, I know it will take some steady hands to glue this back on to prevent plugging on the sensor input.
So if anyone knows of any sort of glue for this application please let me know it would be appreciated.
Thanks
cems
This discussion was "closed" on 03/09/2011 11:57 AM. No comments are allowed.
Message from admins:
Duplicate thread. See original here: http://cr4.globalspec.com/thread/66805
