Previous in Forum: Can I Find Out Temp Through Basic MUC 8051?   Next in Forum: How Much Do Most of us Know About B-vitamins?
In Need of Heat Stroke Monitor Description?
03/10/2011 8:50 AM
In need of heat stroke monitor working principle and its design???
Re: In Need of Heat Stroke Monitor Description?
03/10/2011 2:02 PM
"...heat stroke monitor ..."
Like a thermometer? This site recommends "Place a flexible indwelling thermistor rectally" for constant monitoring. Sorry, I cannot find a suitable image.
Good Answers: 146
03/12/2011 5:18 PM
According to the wiki, heat stroke is defined by a body temperature over 40.6 C.
Body temperature in heat stroke can rise quite suddenly, over a period of minutes. So for your purpose the design might look at rhe rate of temperature change as well as the absolute temperature of the subject at a given moment.
Working principle could be simply defined as a software component which reads data from a sensor component, logs the temperature of the patient, performs simple math to calculate the rate of temperature change over time, and sends a message to activate an alarm component when certain criteria are indicating heat stroke is imminent (temperature approaching 40 C, or rapid temperature rise in the 37-39 C range, for example).
There are a lot of systems available for temperature monitoring - the sensor for starters is an important design variable. This system is designed to monitor exertional heat stroke with a probe type sensor. It logs temperatures but does not bother with the rate of temperature change.
Another system here uses a wireless ingestible sensor. Minimally invasive, I will hope that the sensor is very cheap, so no one will be tempted to re-use it.
One design feature I would include for a heat stroke monitor is to design for the earliest possible sign of heat stroke to trigger an alarm that can't be missed - both audible and visual alarm are best included. This would give you the most time to respond and avoid the risk of physiological damages.
incus opella
Register to Reply 2 comments
