Previous in Forum: Fault in Crane Wiring   Next in Forum: Solar System
Voltage Determination
03/10/2011 9:53 AM
Hi,
How do you determine the Voltage of a motor whose name plate is missing? Is there a test to performe to tell you wheather the winding is 380 V or 550 V?
If you supply a Variable Speed Drive with 550V and connect to it a 380V Motor,and programme the drive according to the motor ratings that is 380V and so on.Will the VSD output be 380V or 550V?
Regards.
Good Answers: 53
Re: Voltage Determination
03/10/2011 9:59 AM
If you program 380 It will not exceed it,
03/10/2011 1:25 PM
Look around the place of its origin - sort of what supplies are there most common, what are other motors' voltages.
If you have 380 V and 550 V sources available, I think, connecting it to the first wont damage it - I mean without any load, for a very short time, and controlling its starting "behaviour," and its current with a clamp meter. If it has 6 leads, better to even try at first in the star connection.
It might even not get revolving, but the value of the start (locked rotor) current would tell you much. (You may further report here) Only be careful!
Register to Reply 2 comments
