Previous in Forum: Six Stroke Engine   Next in Forum: SHEARING STRESS
FIND OUT TONNAGE OF POWER PRESS
03/10/2011 10:26 AM
HO TO FIND OUT TONNAGE OF POWER PRESS?
Good Answers: 53
Power press tonnage
03/10/2011 10:40 AM
Are you looking to buy a power press and want to know the size of power press for your requirement?
If that is the case here is formula
Required tonnage = Perimeter of the component (mm) X thickness of component(mm) X Shear strength of material (ton/mm2 )
Good Answers: 181
Re: FIND OUT TONNAGE OF POWER PRESS
03/10/2011 1:52 PM
Presses aren't to be played about with. They are dangerous!
Imagine a cast steel crane brake drum in a 400-ton press, it shattered. How we weren't we killed? There was bits of steel buried in the brick wall/
