Previous in Forum: Optimal Flange to Web Ratio When Hot Rolling Wide Flange Beams   Next in Forum: Low Voltage Motion Sensor Switch
Copper Circuit Ring for Shaded Pole Motor
03/11/2011 7:32 AM
What is the name of the machine used for copper circuit ring welding in shaded pole motor ? see link bellow for more info. http://cr4.globalspec.com/PostImages/200911/Shaded_pole_motor_448F329A-9E31-B553-F21A86EB5E60B1FE.gif
Re: copper circuit ring for shaded pole motor
03/11/2011 7:45 AM
The shading coil.
See the description of operation here.
Good Answers: 97
Re: Copper Circuit Ring for Shaded Pole Motor
03/11/2011 9:30 AM
A plasma welder is one option:
www.thermadyne.com/IM_Uploads/DocLib_1329_84_2214.pdf
CRTL-Z
03/11/2011 9:38 AM
Oops - I mis-read the question .
Good Answers: 97
03/11/2011 9:46 AM
Your reply was not wasted! Now, I can make my old electric clocks and turntables run backwards!
CRTL-Z
03/12/2011 9:26 AM
Most common name is "Shaded-Pole" motor mostly used now in small blowers in Kitchens & Washroom [Bath room; Toilets] and small house hold apliances.
Shaded Pole Motor
A shaded-pole motor is a type of AC single-phase induction motor. It is basically a small squirrel cage motor in which the auxiliary winding is composed of a copper ring surrounding a portion of each pole.[1] This auxiliary winding is called a shading coil. Currents in this coil delay the phase of magnetic flux in that part of the pole enough to provide a rotating magnetic field. The direction of rotation is from the unshaded side to the shaded (ring) side of the pole.[2] The effect produces only a low starting torque compared to other classes of single-phase motors.
These motors have only one winding, no capacitor nor starting switch, making them economical and reliable. Because their starting torque is low they are best suited to driving fans or other loads that are easily started. Moreover, they are compatible with TRIAC-based variable-speed controls, which often are used with fans. They are built in power sizes up to about 1/6 hp or 125 watts output. For larger motors, other designs offer better characteristics.
The first photo is of a common C-frame motor. With the shading coils positioned as shown, this motor will start in a clockwise direction as viewed from the long shaft end. The second photo shows detail of the shading coils.
Motor
Coil
03/12/2011 9:32 AM
You've repeated my mistake of not reading the question in the original post carefully enough.
Register to Reply 6 comments
Haajee (1); JohnDG (3); Unredundant (2)
You might be interested in: Metal Ring Seals, V-ring Seals, Ring Gages
