Previous in Forum: Panel Board   Next in Forum: Cable
About SWG
03/16/2011 5:06 AM
Good day to CR4 friends,
We get in market is enameled copper conductor... Enamel is coated around copper wire...
now we have S.W.G & A.W.G no's and corresponding thickness(Diameter of conductor)...
I have doubt that,
is this thickness corresponds to copper thickness OR copper+enamel thickness..???
With regards,
Good Answers: 804
Re: About SWG
03/16/2011 7:50 AM
You would have to ask that question of the vendors to be certain, but in general, conductors are sold based n the cross sectional area of the conductor material, outside dimensions are considered consequential.
Good Answers: 164
Re: About SWG
03/16/2011 8:40 AM
Beg pardon, but did you not mean "inconsequential" ?
Well, since the OP is from India, SWG is more common here, unless he is making something for the US market. Anyway, the enamel thickness becomes a factor when winding coils of fine wire in tight spaces. Generally IEC specs give fine, medium and coarse enamel covering. If winding space is tight, i would use good quality F class wire with fine covering.
Good Answers: 44
Re: About SWG
03/16/2011 10:57 AM
Straight answer to your question: "copper thickness".
Register to Reply 3 comments
cuba_pete (1); JRaef (1); kvsridhar (1)
