Previous in Forum: Black Start Generator   Next in Forum: Delta-delta secondary L-G measurements
Wire Size
03/17/2011 8:45 AM
when i know the kw how to find the wire size?
Good Answers: 181
Re: Wire Size
03/17/2011 10:03 AM
Look in the ratings tables. After you've worked out the current.
Good Answers: 244
Re: Wire Size
03/17/2011 9:47 PM
Re: Wire Size
03/18/2011 1:00 AM
If you know the voltage and pf too you can calculate Amps. Then if you have chosen the type of cable,you can find wire size from tables
pnaban
Register to Reply 3 comments
msamad (1); pnaban (1); TonyS (1)
