Previous in Forum: Software _ Beam & Venturi   Next in Forum: Minimum Required Strength
Something About Casting (Gating Design)
03/18/2011 2:29 AM
Hello,everyone! I am back after half a year absence at CR4. Recently I am translating a technical report from EN to CN and there are two phrases that I am totally not familiar with: continuous tapping and Casting on flat
Anyone provide a lead?
I am not a home work cheater. I am a translator seeking professional help
Good Answers: 181
Re: Something about casting(gating design)
03/18/2011 6:38 AM
Continuous tapping usually refers to blast furnaces. A furnace is usually allowed to build up a well of iron and slag, this is tapped off at various times. On very large or cupola furnaces the iron and slag can be run off continuously. As to flat casting I'm not sure, but I've got a rough idea. I'll have a look for you.
Re: Something About Casting (Gating Design)
03/18/2011 12:11 PM
Can you provide more? Maybe the entire paaragraph where they are used. Casting on flat may be as simple as continuous tapping into open top molds, which would leave the top open, or flat with no features on that surface.
03/18/2011 12:19 PM
Where is Milo? it is his area.
Good Answers: 243
03/18/2011 8:38 PM
Hey wingman welcome back. If it is Steel and for mill production, not foundry work, they might actually mean continuous casting through a tundish into oscillating water cooled molds. This makes a solid shelled billet or bloom which is torch cut and then reheated and rolled into mill products my guess might be that casting on flat, again if for steel mill products, might actually mean thin strip casting.
TonyS has given reasonable answers as well, but if it steel for subsequent processing i' d bet on mine
Register to Reply 4 comments
Anonymous Poster (1); lyn (1); Milo (1); TonyS (1)
