Previous in Forum: Material for Netral Earthing Resistor   Next in Forum: Fault Would Occur or Not
Phaseing out
03/18/2011 7:56 AM
Am I correct in my understanding of this
If phase is correct thenbetween panels r to r will = 0 volts
y to y and b to b will also be 0
If phases are crosed then in essence i am measuring across phases and as such will indicate a voltage presance
eg - r to y - volts,,,,r to b = volts ,,,b to y = volts etc etc
thanks
Good Answers: 29
Re: Phaseing out
03/18/2011 8:55 AM
Yes.
Re: Phaseing out
03/18/2011 9:41 AM
Thanks,,,,some time you know how to test things but just need a bit od reassurance
Netherlands - Member - New Member Canada - Member - New Member
Re: Phaseing out
03/18/2011 4:54 PM
If both panels are fed from the same transformer/supply
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use. Galileo Galilei
Re: Phaseing out
03/18/2011 5:23 PM
yes buddy you think right
Re: Phaseing out
03/18/2011 5:30 PM
Thanks Gents
Re: Phaseing out
03/21/2011 4:20 AM
This is only true when using low voltage test equipment, HV testers have built in safety to ensure the HV potential is not available across the two test probes, which results in a higher voltage indication across the in-phase pair being tested.
Register to Reply 6 comments
adnanzlfqr (1); alancdavis (2); jk (1); Plugg (1); RDGRNR (1)
