I'm a Mechanical Engineer working in Santaldih Thermal Power Plant since 1998. Recently our 250MW(6th Unit) M/S BHEL make turbine got a problem of very high axial shift after being synchronized & even got damaged thrust brg. The value shot upto -1.9mm where as alerm at +-0.5mm, tripping at +-1.0mm. Our Lp turbine double flow last stage blades supplied byM/S BHEL was not conventional root fixing i.e. not fir tree joint, this modification done in one side only another side is normal. Could it be the reason of more axial shift? If any body can give me idea about thrust balancing of 250 Mw(nozzle control governing system) turbine(KWU). Is there any balance piston or the labyrinth seal itself neutralizing the thrust caused by steam flow. Pl.give answer. Ramaprasad.
