Previous in Forum: Before and After Shots of Japan   Next in Forum: Meltdown
Reach High Strength with Reclaimed Pavement
03/18/2011 9:02 PM
Hello everybody.... I most reach 2,100 PSI resistency mixing asphalt pavement (4" asphalt plus 8" base course) adding cement or whatever; I know that adding 18% of cement could be reach, but is prohitib expensive... There is any other way to get it ? This new mix will be use as a pavement layer (course), meaning that is very important the relation betwen water-soil... I appreciate for advance
With all due respect
Re: Reach High Strengh with Reclaimed Pavement
03/20/2011 2:15 PM
I have heard that adding reclaimed glass (Crushed) will strengthen and also lengthen the life (dissipates heat) of Asphalt. Glasphalt, I believe, was a trade name--Don't know if it still in development or if it is being used. Some one else will probably know a lot more--
03/20/2011 10:24 PM
Thanks C-Mac... Reclaimed glass.... interesting.... I am affraid could not be tottaly usefull because could be a lot of dangerous and the glass not glu it with asphalt, with the pass of time, could "fly" rigth after the pass of neumatics.
Now I just read that the technology named is "Lean-Mix Concrete"... I am still searching to resolve my situation
Thanks again
03/20/2011 11:13 PM
If you Google Glasphalt, you will find many discussions and technical papers of the process. It is good for some applications, and not as good for others. I do not believe it will leave the matrix, and become a hazard to tires or others. You must dial in your specific needs, and go from there. Hope it is of some help!
Register to Reply 3 comments
