Previous in Forum: Wanted: Silica-Gel Dessicant Sachets   Next in Forum: Magnetizing 304ss Tube
High-Viscosity Lubricant
04/06/2007 11:54 AM
I want to prototype a larger scale slow closing container cover. I found the technology I want to use in the current toilet seat slow closing cover. It looks like they use a high viscosity lubricant to slow down an internal mechanism. I was looking to find out what kind of lubricant this is or a compatible product that might work as well ?
Pathfinder Tags: closing lubricant slow viscosity
Good Answers: 120
Re: High-Viscosity Lubricant
04/06/2007 11:00 PM
if the cover closes of it's own weight they commonly use a hydraulic cylinder or air cylinder that opens freely and as it closes it then pumps the air or fluid through an adjustable aperture. You can get light weight ones to close screen doors that use air. The heavy duty closers use a fluid. Another way is a pully set with an adjustable crimp brake on one of the pulleys.
Per Ardua Ad Astra
04/07/2007 6:25 AM
Damping grease inhibits free motion and quiets the noise associated with metal-on-metal, metal-on-plastic, or plastic-on-plastic devices. A staple in automotive controls, stereo tuners, camera zoom lenses, and microscope focus mechanisms, Nye's family of damping grease is a cost-efficient way to build smooth, controlled, quiet motion - a "velvet feel" - into mechanical and electromechanical devices. This is from; http://www.nyelubricants.com/damping.php?section=Lubricants-SpecialtyProducts-DampingGrease
Good Answers: 183
04/07/2007 7:30 AM
Look at silicone oils they are more stable in temperature (less change versus temperature) than mineral oils and one can mix them to required viscosity. I think dow-corning is a supplier. use google for search.
Register to Reply 3 comments
aurizon (1); clear blue (1); nick name (1)
