Previous in Forum: AIST Report No 7   Next in Forum: Advantages/Disadvantages of Gear Boxes
12 comments
Gd and T
03/21/2011 7:57 AM
Hi,
I Gd and T what is meant by Primary secondary and teritary datum.what is meant if it is given datum A B C?
Thanks
Good Answers: 137
Re: Gd and T
03/21/2011 8:24 AM
What on earth are you talking about?????????
Good Answers: 29
Re: Gd and T
03/21/2011 8:41 AM
Primary secondary and tertiary
First, Second, and Third.
Re: Gd and T
03/21/2011 9:01 AM
Can u please explain me what does this mean.suppose a feature is given with all the 3 datums.which one should i consider?
Good Answers: 137
Re: Gd and T
03/21/2011 9:32 AM
What do I, Gd and T mean? What is the context? Is datum a level datum? In UK we have levels AOD = Above Ordnance Datum.
Codey
Good Answers: 181
Re: Gd and T
03/21/2011 5:48 PM
Dam it, I thought you were talking about Gin and Tonic but then noticed the d
Re: Gd and T
03/21/2011 6:00 PM
I'll bet that Gin and Tonic, under the right conditions could also," allow the use of mating parts that would otherwise have been rejected if using conventional inspection techniques.
Re: Gd and T
03/21/2011 9:18 AM
Who's on First
What's on Second
I don't know = 3rd
http://www.youtube.com/watch?v=sShMA85pv8M
sorry, just feeling a little witty this morning.
Re: Gd and T
03/21/2011 9:42 AM
Its the X,Y and Z datum.
Ron
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Anonymous Poster #2
Re: Gd and T
03/21/2011 9:43 AM
GD&T = Geometrical Dimensioning and Tolerancing ANSI Y14.5
The primary, secondary and tertiary datums define the precedence and are shown in call-out block from left to right
eg | | | Φ0.1| A| B| C|
Will show primary datum as A, secondary as B and Tertiary as C
The order of precedence means how the practical inaccuracies are addressed.
let us take two reference surfaces A and B, defined to be perpendicular to each other within 0.02mm and are primary and secondary data.
Obviously these two are going to have their flatness problems (errors) too.
The primary datum now you can consider as if the component is put on a ideal flat surface and made to contact the surface "A" with it on at least two points. Let us call this surface as DA
Now put another surface exactly perpendicular to the surface in contact with A ie DA (remember it is ideal surface and exactly perpendicular). Obviously the surface B can not now have contact with this surface DB. At the best you can have one point in contact. DB is the secondary datum.
These are easily generated on CMM.
Anonymous Poster #2
Re: Gd and T
03/21/2011 9:46 AM
There is a link you can go through to understand the concept.
http://www.meadinfo.org/2009/05/gd-datum-better-insight-asme-y145.html
Good Answers: 137
Re: Gd and T
03/21/2011 11:26 AM
It's OK, I'll take your word for it
Re: Gd and T
03/21/2011 2:00 PM
Correct.
Geometric Dimensioning and Tolerancing allows the use of mating parts that would otherwise have been rejected if using conventional inspection techniques.
Anonymous Poster (3); Codemaster (3); johnnybravo (1); lyn (2); RDGRNR (1); ronclarke (1); TonyS (1)
