Previous in Forum: Centrifugal Pump   Next in Forum: How Pipe Natural Gas is Cheaper than LPG
U.S. Equivalent for Klubersynth G 34-130
03/24/2011 5:13 AM
We have a point-to-point router that needs this lubricant. it is most difficult to find locally. we want to buy american. does anyone know what the United States version of this lube is?
Klübersynth G 34-130
Special grease for small gears
The data in this product information is based on our general experience and knowledge at the time of printing and is intended to give information of possible applications to a
reader with technical experience. It constitutes neither an assurance of product properties nor does it release the user from the obligation of performing preliminary tests with the
selected product. We recommend contacting our Technical Consulting Staff to discuss your specific application. If required and possible we will be pleased to provide a sample
for testing. Klüber products are continually improved. Therefore, Klüber Lubrication reserves the right to change all the technical data in this product information at any time
without notice.
Klüber Lubrication, a member of the Freudenberg group
Publisher and Copyright: Reprints, total or in part, are permitted if source Klüber Lubrication München KG
Klüber Lubrication München KG is indicated and voucher copy is forwarded. Geisenhausenerstraße 7, 81379 München, Deutschland
�� +49 89 7876-0, Telefax +49 89 7876-333, www.klueber.com
Product information 5.177 en
Edition 04.09, replaces edition 05.08
Article number: 020501 MA-SP/SP
Description
Klübersynth G 34-130 is a
lubricating grease based on
synthetic hydrocarbon oil, mineral
oil, special Ca soap and polyurea. It
has a wide service temperature
range, good antiwear properties and
high resistance to ageing.
Klübersynth G 34-130 provides
excellent protection against
tribocorrosion resistance to water
and good adhesion.
Application
For gears, bearings, joints and
slideways, for example in machines
for craftsmen and do-it-yourselfers.
Generally suitable for small and
miniature gears with steel/steel,
steel/plastic and plastic/plastic
friction components.
Klübersynth G 34-130 is particularly
suitable for slideways with
aluminium sliding components and
for the lubrication of trapezoidal or
ball-type threaded spindles.
Application notes
Immersion lubrication of gears up to
a peripheral speed of approx. 5 m/s
and for tooth flank greasing up to
approx. 4 m/s.
The product is applied by brush,
spatula or automatic metering
devices*.
* The product can normally be applied by means of
centralised lubricating systems. Please note, however, that
due to different system configurations and application
conditions the pumpability of the product has to be
confirmed for each individual application. We will be pleased
to provide assistance in this matter.
Service temperature range
We recommend a general service
temperature range between approx.
- 30 and 130 °C.
Immersion lubrication is possible
starting from approx. - 20 °C, and
the applied lubricant film (e.g. on
tooth flanks) is functional to approx.
- 40 °C.
Indicated service temperatures are
guide values depending on the
lubricant's structure, the intended
use and the application technology.
Minimum shelf life
The minimum shelf life is approx. 24
months if the product is stored in its
unopened original container in a dry
place.
Pack size
1 kg can
25 kg bucket
Material safety data sheets can be
downloaded or requested via our
website www.klueber.com. You may
also obtain them through your
contact person at Klüber.
Product data:
Colour beige-light brown
Texture homogeneous,
short-fibred
Density, at 20 °C, [g/cm3], approx. 0.87
Drop point, DIN ISO 2176, [°C] > 180
Consistency grade, DIN 51 818, NLGI 0
Worked penetration, DIN ISO 2137
(ASTM D 217); [0.1 mm] 355 - 385
Base oil viscosity, DIN 51 562,
at 40 °C, [mm2/s], approx.
at 100 °C, [mm2/s], approx.
150
16
Apparent dynamic viscosity,
Klüber viscosity grade** EL/L
** Klüber viscosity grades: EL = extra light lubricating grease; L = light lubricating grease; M = medium lubricating grease;
S = heavy lubricating grease; ES = extra heavy lubricating grease
• Special grease for small
gears
• Suitable for aluminium
components
• Wide service temperature
range
• Good protection against wear
• Excellent protection against
tribocorrosion
• Easily applicable through
automatic metering devices*
your help would be most appreciated
alex.
Good Answers: 266
Re: U.S. equivalent for Klubersynth G 34-130
03/24/2011 7:35 AM
Google Cross references for the grease. Below is a cross reference from FINA. It list a comparable replacement.
http://www.performanceoilstore.com/information_files/totalindcrossref.pdf
