Previous in Forum: Permanent Magnet Generator - Fixed Load?   Next in Forum: Indicating Lights
Electricity Network - Operating Criteria
03/30/2011 10:01 PM
What is N-1 & N-0 criteria of Electricity network? Is there any other criteria as well?
Rajesh
Pathfinder Tags: electricity N-1
Good Answers: 445
Re: Electricity Network - Operating Criteria
03/31/2011 9:59 AM
More information about the context of this question is required to answer it.
03/31/2011 6:20 PM
Not sure what more info I should provide. I recently came across these terms in the context of Transmission & Distribution network and would like to know more about it. My background is of a Switchgear design and did not ever heard of N-1 or N-0.
Rajesh
Good Answers: 445
03/31/2011 10:59 PM
I checked my T&D manual and couldn't find any obvious use of the nomenclature, I can only guess it refers to different states of the network. If you can provide more info then perhaps I can too.
04/01/2011 1:35 AM
I understand that N-1 network will be deficient in installed resources than normally required. e.g. the system configuration is designed in such a way that one less breaker is installed than ideally required. This saves capital cost.
But this is only brief info. I would like to know more. Searched on iternet but could not get any definitions.
Rajesh
Good Answers: 445
04/02/2011 12:41 PM
My guess (and it is really a stretch) is that you've stumbled into a system stability/security question where the 0 represents the prefault or steady state operation of the network and the -1 represents the network state after the fault of any single item in it, etc. Try googling on "Power system stability" or "...security" If that isn't your topic then maybe someone else can help.
