Previous in Forum: Harmonic Distortion   Next in Forum: Reactive Power?
About Current Transformers
04/01/2011 8:46 AM
Dear sir, i wanted accurate voltage as output from current transformer for that i have connected one resistor parallel to the out put of CT, then i getting the voltage but not accurately. so please help and tell me how to get the good results. thanking you sir
Re: About Current Transformers
04/01/2011 1:45 PM
Accurate voltage will not be you got from CT that you give resistor,
because your CT is in series with Load. and then between Source (220V or 380V or 11kV or 20kV) to Load you give CT.then you put resistor in there. so your voltage is change following the change of your load.
better you use VT in paralel with your source to get stable voltage.
thanks & warm regard
Good Answers: 181
04/01/2011 5:24 PM
As far as I'm aware you should get a linier voltage range. I've used this method for under load detection for belt driven fan drives.
Good Answers: 11
04/03/2011 1:55 PM
Your load resistor probably has too high a resistance. Try it with a load resistor of much less than 1 ohm.
OR put your mutimeter on 10 or 20 amp AC and connect directly to the current transformer output. CAUTION: Verify that you multimeter is working correctly before doing this. If the multimeter has an open fuse or is not working correctly, you may destroy both the multimeter and the current transformer.
04/03/2011 3:58 PM
Are you exceeding the burden rating of your CT or driving the CT outside its linear operating zones?
Are you wanting a fixed voltage but it is changing as your current changes?
What are you using the voltage for?
Can you please supply more information regarding your application.
Good Answers: 170
04/06/2011 12:06 PM
I assume that you are measuring the CT Secondary Voltage with a Voltmeter. If so, voltmeters have a very high Ohmic burden. If this burden is more than the CT Rated Burden, then definitely the CT accuracy will be affected.
Carl Pugh (1); elect-ok (1); electricalexpert65 (1); jack of all trades (1); TonyS (1)
