Previous in Forum: Help - Need pump Pulseless Flow, 2000 PSI, 100 cc/min   Next in Forum: Basis on Which Price is Determined?
Adhesive for Installing Polycarbonate Roofing
04/04/2011 2:00 AM
What is the best adhesive normally use for installing polycarbonate roofing and metal roofing? I guess its a silikon + aspalt ( in roll ). But I'm not so sure whats the name. Please advise or furnish me with any reference that I can refer. Thanks.
=D
Re: Adhesive for Installing Polycarbonate Roofing
04/04/2011 9:44 AM
Here's a list that may give you some ideas.
http://www.bestmaterials.com/metal_roof.aspx
04/05/2011 12:19 AM
I my experience Corrugated roofing is installed with Tek Screws
Metal roofing:
<http://www.getprice.com.au/m6-x-50mm-roofing-screw-suit-timber-and-metal-per-1000-gpnc_264--23394315.htm>
Polycarbonate:
<http://www.boltsnutsscrewsonline.com/box-of-100-polycarbonate-roofing-screws.5480>
or
<http://affordablepergolas.com.au/building-materials/Laserlite_2000.pdf>
here is a summary of fixing methods:
<http://www.buildex.com.au/pdf/Roofing_selection-chart.pdf>
Also be aware that there are minimum screw spacings, and the requirement for an oversized hole to be drilled under the rubber washer to allow for thermal expansion of the polycarbonate - thus the integral cutters on some of the polycarbonate screws.
If you don't use these screws you will need a separate cutter to drill the appropriate sized hole before inserting each screw.
see also <http://www.ibs.com.au/suntuf-polycarbonate-roofing-sheets.html>
Alternatively if you are using the LEXAN style multiwall polycarbonate flat sheeting
you probably need to use the manufacturers proprietary installation hardware eg:
<http://www.ampelite.com.au/images/Lexan%20Thermoclear%20Installation.pdf>
04/05/2011 12:11 PM
Adhesive if used would be a roofing silicone sealant. Do not use clear sealant it will eventually peel from the polycarbonate in a short time use the gray colored type as it resists the UV best.
Normally Tek screws with rubber bumpers are used to secure this material the sealant is only used for repairs not to secure the roofing.
Register to Reply 3 comments
garth (1); kramarat (1); WAWAUS (1)
