Hi all
I have a 415V starter connected to a 1.1kw (2.5A flc). I am using a 3pole 32A socomec Fusebloc (part No.3841 3103) with a 10A fuse protecting the motor.
my question is how do I select the double insulated cable in the fault free area going from the mains supply to the unprotected side of the fuse switch. I have a standard selection sheet that recomends 10mm double insulated for a 32A fuseswitch but I would like to know how these values are obtained.
