Previous in Forum: Construction Drawing Symbol   Next in Forum: Clay Pipe Thickness Determination
Strength of Reinforcement and Deflection in the Beam
04/06/2011 7:12 AM
If I use reinforcement with low strength (yield) is that any realtion in the beam deflection
Pathfinder Tags: deflection and steel
Good Answers: 74
Re: Strength of Reinforcement and Deflection in the Beam
04/06/2011 11:41 AM
No, because Young's Modulus is very nearly the same for all steel.
Bruce
04/06/2011 3:35 PM
thats mean if we use the reinforcement steel (Fy=2800kg/cm3) dont not cause any deflection in beam
Good Answers: 74
04/06/2011 3:57 PM
  • I don't understand your question.
  • Load causes deflection, not Fy.
  • Your units for Fy are incorrect.
Bruce
Good Answers: 74
04/06/2011 6:27 PM
wisam,
Just to be clear, for two beams reinforced with identical reinforcement having two different yield strengths, the deflections should be identical for identical loads.
If the beam with the lower strength steel requires more reinforcement to carry the load, then the area of steel increases, so moment of inertia increases, hence deflection decreases.
So you could say that deflection is indirectly related to Fy.
Bruce
04/08/2011 1:17 PM
ba/ael
I mean with my question if I have two beam,
1-if two beam carry the same load but each one have reinforcements with different yield strengths.
2- if two beam carry different load but each one have reinforcement with same yield strengths.
which case have more deflection?
Good Answers: 74
04/08/2011 2:03 PM
  1. Deflection is equal if bars are same size.
  2. Deflection is proportional to load.
Bruce
Good Answers: 179
04/07/2011 1:44 PM
ba, good answers, but I wouldn't waste my time on this one as he/she needs to go back and study the basics and principals of reinforced concrete design and analysis again....and again.....and again...... :-(
For the OP: Obtain a copy of "Reinforced Concrete Design" authored by Professors Leonard Spiegel, PE/PhD and George Limbrunner, PE. Study in hard and thoroughly if you want to be a successful Civil Engineer!!!
If you are lucky you'll be able to download a free Ebook of the textbook, or you may find a cheap used copy (older Edition) in Ebay or Amazon.com. I learned reinforced concrete design from this book when it was only in a rough manuscript format (mimeographed pages....not even photocopied. I still have it in my professional reference library after all of these years!!!! LOL) way back in my community college days over 33 years ago, then graduated to Wang & Solomon's wonderful textbook (much more involved). In fact, the late Prof. Spiegel was head of the Civil Engineering Technology Dept. at Hudson Valley Comm. College. Prof. Limbrunner was one of the CET staff there and is a former US Navy SeaBee. I learned a lot from both men and am forever grateful I was one of their students!
Register to Reply 7 comments
ba/ael (4); CaptMoosie (1); wisam2036 (2)
