Previous in Forum: Circuit Analysis   Next in Forum: Hitachi VFD
12 comments
Protection of Transformer
04/09/2011 3:28 PM
What is the biased differencial protection of transformer
Good Answers: 181
Re: protection of transformer
04/09/2011 3:33 PM
04/09/2011 4:46 PM
Re: http://wiki.answers.com/Q/What_is_biased_differential_protection_realy it took 10 seconds to find
And here's the answer you found in those 10 seconds:
this is additionl of differential realy......"
To be fair, there were pointers to answers to somewhat similar questions on the same page. I am not the OP, I know what differential protection is on a transformer, I still don't know what biased differential protection is.
04/09/2011 10:51 PM
Actually transformer differential protection is located on that page. I am quite amazed as I do not find wiki.answers to have been accurate in past years.
"Real Bass Players" do not use picks
04/10/2011 6:54 AM
So, what is "biased differential protection"?
Good Answers: 42
04/09/2011 11:30 PM
"The differential protection used for transformers is based on the principle of current circulation. This type of protection is mostly used for transformers as this responds not only to inter turn fault but also provides protection against phase-to-phase faults"
A complete description of differential protection of transformers is given in the following link.Please read complete text and see the drawing ,a fairly good explanation of the subject is available.
http://electricalandelectronics.oplanation erg/2009/03/19/differential-protection-in-
transformers/
04/10/2011 7:07 AM
That link doesn't work for me, even when I paste "transformers/" on the end and replace oplanation with explanation. Also, when I paste electricalandelectronics it shows up with spaces and I tried replacing those with %20.
Hopefully, this one will (from google):
DIFFERENTIAL PROTECTION IN TRANSFORMERS
I did a quick search on that page for the word biased--nothing shows up. Is there something that discusses biased differential protection on that page?
(I am not the OP, just would like to learn.)
Good Answers: 164
04/10/2011 9:13 AM
There is another thread on this very subject, maybe the answer is there :
http://cr4.globalspec.com/thread/35342/Biased-Differential-Relays
Perhaps biasing implies deliberate skewing to compensate for tiny errors in manufacturing.... i am going to read some more... maybe the Areva link there...
Some reference to biasing on the Transformers UK page....
Biased Relays
The use of a bias feature within a differential relay permits low settings and fast operating times even when a transformer is fitted with an on-load tapchanger (see above). The effect of the bias is to progressively increase the amount of spill current required for operation as the magnitude of through current increases. Biased relays are given a specific characteristic by the manufacturer.
04/10/2011 12:35 PM
Thank you!
04/10/2011 12:36 PM
Thank you!
Good Answers: 170
Re: Protection of Transformer
04/10/2011 10:04 AM
If you are from India, please try to attend a 4-days duration training programme - "Digital Relays for Equipment Protection (DREP)" - offered by L & T at their Switchgear Training Centres at Pune, Lucknow & Coonoor.
04/10/2011 4:23 PM
Still plugging for a fast buck EE
Good Answers: 170
04/10/2011 9:01 PM
Yes! But, how does that matter to you? If you are not interested, please keep quite.
Register to Reply 12 comments
Anonymous Poster (1); electricalexpert65 (2); Jimh77 (1); kvsridhar (1); rhkramer (5); TonyS (1); V.I.Abraham (1)
