Previous in Forum: Laser Gun   Next in Forum: Earth Rod
Nigeria - Member - New Member
Solar Estimator
04/11/2011 11:37 AM
would the solar panel inverter(AC) give you the same power as the wattage of the solar panel(DC) itself
got Jesus
Good Answers: 181
Re: Solar Estimator
04/11/2011 1:09 PM
No you will have losses in the inverter.
Good Answers: 125
Re: Solar Estimator
04/11/2011 4:32 PM
No, expect about a 10% power loss. If you can wait a year, the panels will each come with built-in micro-inverters which will give you about a 98% efficiency. Also be aware that panel wattage is specified under optimum conditions (perfect alignment, brightest sunshine, shiniest sales pitch) and usually you will put out less than stated power.
Register to Reply 2 comments
