A forward-reverse DC motor was working perfectly in our mill;How do i correct the following:(1)sometimes when forward push button is pressed,it moves forward & at times it behaves otherwise(reverse),(2)It also takes high current
You may use contactors which have mechanical interlocks also. When forward action is on then reverse contactor cann't be picked up and vice-versa. You may also check the control ckt. thouroughly to check any leakage or contactor sluggishness etc.
