Previous in Forum: Diameter Difference Measurement Sensor   Next in Forum: What is Fieldbus & Modbus
8 comments
Search For RPM Sensor For Analog Devices 5B45-05 f/v
04/16/2011 8:48 AM
I'm a retired calibration & controls guy.
I have a client with a testing machine that uses a 60 tooth wheel for rpm.
The sensor (magnetic? hall effect? prox?) was lost. Of course, no records.
The sensor's output was sent to an f/v converter - Analog Decives, Inc. 5B45-05.
Spec. pdf is at:
http://www.analog.com/static/imported-files/data_sheets/5B45_46.pdf
Have tried pnp & npn prox's, but ng.
I would like to find a 3/8" x 1" hall effect or magnetic sensor that would work with the existing 5B45 f/v.
Alternatively, I could replace the f/v converter with another model that accepts a standard hall effect sensor.
I need to have 0-5vdc=0-10,000rpm output from the replacement.
I can even go to a photo sensor, if you think it best. There's a 6-black/6-white disk I can use for that.
Thanks for your help.
Re: Search For RPM Sensor For Analog Devices 5B45-05 f/v
04/16/2011 11:42 PM
Chances are it is just a 2 wire magnetic pulse train prox that picks up the signal as the teeth pass by in a TTL input to the converter.
"Real Bass Players" do not use picks
04/17/2011 8:02 AM
thanks Jimh77
it's 3 wire -,+ and signal
the problem is (in pdf) the 5B45 triggers when the input crosses zero volts or 1.4 volts when biased (it's not biased). the sensor sales guys here say it's a strange f/v converter to use for rpm, but somebody did.
also, there's a speed issue - at 10K rpm the wheel produces 10KHz and that's pretty high for a prox.
thanks again for your help
I'm thinking of ripping out 5b45 - what's a good sensor + f/v recipe to replace it with?
tommyt
04/17/2011 9:30 AM
I would say remove the old system and replace with a new current speed measure system. There are plenty to choose from. Digital being the most reliable and accurate. A tacho-gen may work for you.
Forget about the prox switch never going to be reliable or repeatable!
repeat problems can not be solved by the same way of thinking ( A. Einstein)
04/17/2011 10:32 AM
I agree with your replace idea...tach-gens are too $ for this app, however.
Unless someone responds with knowledge of the 5B45's sensor selection,
I plan to replace with a $110 3/8" spectec hall effect sensor & one of their small $40 f/v's to work with the gear tooth wheel.
I've also got a black/white wheel on the same shaft - I may look at a diffuse optic sensor. Would still replace the f/v, though. Can u recommend good one?
thanks again
tommyt
04/17/2011 2:11 PM
Speed is the main consideration as you know with an actual frequency of 166HZ a 300hz reaction time is what I would suggest. I know of none made today that can do that, sorry. As far as manufacturers go I normally use either Banner or Turk. I have used automation direct in the past with good results.
04/17/2011 12:38 PM
Tommy, I am still leaning towards the 2 wire TTL magnetic prox based on this info:
http://www.dataq.com/support/documentation/pdf/manual_pdfs/di5b45.pdf Terminals 2 and 3 up to 10Khz. I have used things like this years ago. I haven't done anything with these since 1986. Most of the equipment I built back then all had Red Lion controls.
OK, I stand corrected on the 2 wire, these can only handle up to 250Hz. Take a look at these:
http://www.redlion.net/Products/Groups/MagneticPickups/LMPC-AmplifiedMagneticPickup/Docs/11004.pdf
Hope some of this helps.
Jim
04/19/2011 5:55 PM
TommyT, I am a Measurement Engineer & I have been using Hall Effect Magnetic pick-ups with a 60 tooth gear or wheel, to aaurately measure RPM for 32 years. I have also used several other technologies including optical.
The 60 tooth gear with a magnetic pick-up is my preference, because it is 'bullet-proof' & has stood the test of time, especially in a control situation. The reason for using a 60 tooth gear is so that RPM can be read directly by any standard frequency counter in Hertz ( 60 Hz(i.e. 1/sec) per Rev/(60 sec per min) = RPM).
There are 2 different types of Hall Effect magnetic pick-ups, Passive & Active. Passive types do not require external power & have a 2 pin connector. With a 60 tooth gear it will work accurately from 300 RPM to 20,000 RPM. Active types (also known as Zero Velocity types) require power in the range typically of 5 to 24 volts DC, and will work accurately from 0 RPM to 30,000 RPM. Active pick-ups require a specific mounting orientation whereas most Passive types do not.
I can send info on Manufacturer's that I use. I also have good used pick-ups of both types.
On the Analog Devices Module, either type should work fine. A negative trigger voltage should not be a problem. Paul
04/27/2011 7:56 PM
If you do not need to sense zero or very low speeds then a common passive (self generating) magnetic speed pickup will work. Look at this page and scroll down to the "Principles of Operation" section:
http://www.motionsensors.com/speed-sensors/variable-reluctance-speed-sensors.shtml
There are many manufacturers of similar sensors.
If you do need to sense very low or zero speed then one of the powered hall effect types would probably do OK.
Optical is difficult if you need to sense in dirty environments so I tend to avoid it. Just about everything I have anything to do with is dirty in one way or another.
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
Register to Reply 8 comments
dthomas16 (2); Jimh77 (2); Paul Morgan (1); TommyT (2); Turbotroll3 (1)
